weird mpg..? HELP
Yongee
Active Member
19
11
Sooooo. Since I bought the car, I've been trying to see if I can reach the 28mpg mark driving like a grandma on any given street, but the problem lies when I leave the car off and get back in it. I would set it at around 27.6 mpg after 20 miles, next day get in and start my car it'll be at 24mpg.
Anyone else have this problem?
Is it a leaking fuel tank?
I checked the bottom of the garage before leaving, and there is no puddle or anything.
Lastly, until 2k miles, I was getting about 16mpg (drove like a madman) is that the reason why my mpg is so unstable?
PLEASE HELP KUDOS TO ANYONE AND EVERYONE!
Nix
Jötunn Moderator
10,765
8,162
Lew-vul, KY
It's A Fast Pig!
It's averaging. When you start it up you are getting 0 mpg. Don't rely on the guage. When you go to the gas station divide miles driven by gallons in. The guages are an estimate and can be up to 10% off. If there is an instantaneous setting to view current mileage you can watch that fluctuate wildy to give you a better idea of what it's trying to do. You do not have a fuel leak over 3.6mpg difference in the display.
KennyGS
How may I help?
11,644
5,513
Keystone State
:yeahthat:
> Go to a pump that you will return to later.
> Fill up until it clicks off.
> Zero your trip meter.
> Drive until mostly emptied (below 1/4 tank)
> Return to exact same pump.
> Record gallons.
> Divide miles driven by gallons to fill tank.
squiggy
Cartographer
Super Mod
11,183
6,654
Michiana
'12 Civic Si
DBP II Coupe
:yeahthat:
> Record gallons.
I read this as if it was popping up on an old computer with a green crt monitor using text to speech software.
323
Modifier
5,252
3,682
Chicago
Press any key to continue...
Yongee
Active Member
19
11
LOL. never seen that key before in my life. thanks for the update guys!
