Sedan wing spoiler on Si?
iShoot22
3
0
Hey everyone, I just bought a brand new 2012 Rallye Red Si Sedan yesterday, and I have a quick question. I asked the salesperson before I got the car and he said they wouldn't do it, but does the taller wing spoiler found on base civic sedans fit on the Si sedan? I know it would "fit" but would it be direct replacement or would it be more of a hassle to fill in the current bolt holes and re-drill for new ones?
Thanks!
Mike
so if I understand... you want ^^ spoiler on your Si instead of the one below?
some members have sought out users with the same color car and swapped entire trunks. I don't know that the the hole pattern is going to be 100% identical if you'd try to remove/replace. You may end up drilling additional holes.
I removed my spoiler to see whats under there and there are 9 holes left behind. I say don't do it.
watching the vid - it has 3 holes on the drivers side, and 2 holes on the passenger side
View: http://youtu.be/nScgQdeXMBA
you had 9 holes under the spoiler??? 4 on one side / 5 on another? Or are there holes all along the whole trunk?
There are 4 10mm bolts that get removed. Then there are 4 or 5 plastic tabs that snap in and are nearly impossible to remove without breaking. then there is the big hole for the brake light.
