Honda-Fan
MORNING
Time for the weekend
Gonna rain lol
Looks like it sold pretty quickly.This is hard to read and see.
Giant dent on the passenger fend, paint coming off the trunk. Probably been in an accident and not painted properly. Oh and I guess it's turbocharged. And it's way over priced.
https://www.facebook.com/share/1HYuv28uoi/
Someone got a shitty civic si.Looks like it sold pretty quickly.
https://hondata.com/help/flashpro/index.html?launch_control_adjustable.htmi wish you could turn launch control off and on with a button with flashpro. i want to turn it off to do a burn out and then turn it back on to launch at a specific rpm.
Where did you find that info? I can't seem to find it. Anything I search shows up for s300, nothing to do with flashpro.Looks like you can wire a toggle switch that can turn it on/off. I see some posts on the hondata forum saying they use their ac switch to turn it on and off.
The Hondata FlashPro burnout switch is a feature that allows racers to control a lower rev limiter during burnout while keeping the higher rev limiter for launch control and anti-lag. This feature is useful for warming tires without risking over-revving during the burnout. The burnout switch can be wired to the ECU's B5 input, typically using a toggle or rocker switch.
Here's a more detailed explanation:
- Purpose:
The burnout switch is designed to activate a lower rev limiter specifically during burnout, allowing racers to build boost and warm tires without exceeding a certain RPM limit.
- Function:
When the switch is engaged, the FlashPro will use the burnout rev limiter, which is typically set lower than the standard rev limiter.
- Wiring:
The burnout switch can be wired to the ECU's B5 input, which is typically a 5V or 12V input. You'll need a voltage source (12V) and a wire to connect the switch to the ECU's B5 input.
- Benefits:
This feature helps to prevent over-revving during burnout, which can damage the drivetrain, especially when using large tires.
- Usage:
The burnout switch is typically used in conjunction with Launch Control/Anti-Lag settings. You can engage the launch control/anti-lag with the clutch in, build boost, and then release the clutch while the burnout switch is activated to perform a controlled burnout.
- Re-engaging Launch Control:
After the burnout, you can flip off the burnout rev limit switch and re-engage launch control/anti-lag before launching for the race.
- Integration:
The burnout switch is integrated with the Hondata FlashPro tuning software, allowing for customization and adjustment of the rev limiter settings.
https://www.hondata.com/forum/viewtopic.php?t=14165
Question about your Boxster since I see some come up nearby on marketplace every now and again: Is yours fairly stress-free?
Bought a used ashtray for the center console on the boxster, immediately cut it up to make it use the old one’s lid, but now the damn thing stays closed while i drive.
Depends very much on the year and trim. Mine has been pretty good, so far only major things have been starter and brake rebuild, but will need a suspension overhaul soon just from ageQuestion about your Boxster since I see some come up nearby on marketplace every now and again: Is yours fairly stress-free?![]()
