Dad
You're good! I just wanted to throw your quote in there for clarification
It's a shop we use at work for body stuff. He did it for free, I didn't know he was going to do it for free. But said if I sand it and bring it back he will do it again.Will the guy at the shop not sand it for you? I'm guessing he said 600 just to make sure you have a flat surface again so he doesn't have to do a bunch of layers of clear.
Do you know this guy? Doing you a favor?
Why stop at 5p? Probably on until 7p only stopping to make dinner…5am-5pm?
Man. I just spent 10 minutes with 600 wet and it was slow. I think I'll stick with 600 and drop it off in the morning.600 is pretty aggressive I would start at 1200 or 1500 for wet sanding
i just finished sanding with 220 dry and then again with 600 wet and there are a tone of low spots between the carbon weave. i feel like clearing it again will result in a slightly better end product but not smooth like i want. i ordered some epoxy resin and im gonna try a few thin coats and go from there. im past the point of return as i drilled the rivet off the name plates and taken them off to do a good job.I would step up the grit and dry sand the really bad areas and get a tac rag to try to give the new clear coat a chance. I feel like this dude didn't prep this thing at all
i also think they didnt prep at all since a lot of the clear was coming off with my finger nail once i started sanding it down. more so in the groove. im just curious if the epoxy resin will give enough uv protection once done or if i should clear it after.
Also a little concerned with the white from sanding. Is that going to show up when I epoxy it? How do I even get that out.
just tried some compressed air which worked well. still some small ones in there, im assuming some more water and compressed air will get it all out if not some solvents. im just worried to apply anthing that will effect the piece in a negative way.
Replied to your message also.....sorry for replying so late.
Great SuperMod...
It's called work old man.....Great SuperMod...
He doesn’t work too longIt's called work old man.....
