I know vit repeatedly said the knock sensors on the 9th were really sensitive. Is your tune custom, or are you using a flashpro map they provide?Technically there is no "acceptable" knock, but the knock sensors on these cars tend to be very sensitive so you'll register a random count here or there without any legitimate knock.
E tune with e tunez. Same one for 2 years.I know vit repeatedly said the knock sensors on the 9th were really sensitive. Is your tune custom, or are you using a flashpro map they provide?
How do you not remember if you put in 87 instead of 93?wonder if I put 87 octane by accident last fill up.
you mean 91.How do you not remember if you put in 87 instead of 93?![]()
Forgot some folks only can get 91 lolyou mean 91.
Higher altitudes… air is less dense which leads to the car running rich. Lower octane (91 vs 93 premium or 85 vs 87 regular) let’s the car run properly when you’re say a mile above sea level in Denver or wherever.Forgot some folks only can get 91 lol
this shows compatible for the 2012-2015 si trim.I bought these today. I can't find any info online about them and if they're the right ones for the si.
This might be confusing.
Finished the 2.0l wrangler replacement engine. The day I installed it parts manager comes out and says it said to order an updated fuel rail pressure sensor with the engine. 2.0l is direct injection. So I'm a little annoyed at that point until I realized the sensor was easy to get to. So fast forward to yesterday, finished the job. Went to replace the sensor to find out the one that came with the new engine is a 3 pin sensor and the new one is a 4 pin. Sensor on the old engine is also 4 pin.
So obviously I the engine harness that came with the engine is a 3 pin connector and it's not going to work so I decided to put the original sensor back in but sure enough it throws an engine light. So now I'm stumped on what to do. I could swap the engine harness but that's a big job in the vehicle. I took the harness out of the loom to see if there was an extra wire hiding in it but there isn't. I emailed tech line to see what they say.
its a 2021 with 15k kms.Just tell the customer the car is F'ed and they need everything new.....or go buy another vehicle. lol
I believe you are coming down with a cold and will be out the next 2 weeks.....lolits a 2021 with 15k kms.
Wasn’t that the premise of Zombieland? Mad Cow Disease or something like that?Mad cow disease
I had to look it up, but that's right. I completely forgotWasn’t that the premise of Zombieland? Mad Cow Disease or something like that?
