- 57,093
- 24,242
No clue man. I don’t want to say yes, and then a belt snap or something else goes wrong.
Hey Tak, I noticed that you did the 2013 Si OEM rear sway swap. How's that holding up? Did that bolt right up?
Also, were you able to find 93401-10020-008 - Stabilizer Holder Bolts, or did you reuse the old ones? That part number doesn't seem to pull up anything other than posts regarding this swap.
EDIT: Was it actually 93401-10020-08 - Bolt-Washer (10x20)?
Right on. Thanks for the response!
Good thing it was only the AC compressor!
So my AC compressor pulley broke and it's partially seized the belt at 66k on my r18 which I found early. I thought this thing start showing failures at 100k. Now I am wrong and need a lesson learned.
As a preventative maintenance, how often do we check the belt and those pulleys? How often do we check and replace the belt? Is it until we see or hear the noise? What is the best way to keep them running optimal?
Thanks
I got the Android head unit on ebay. It’s an non brand name Android head unit from China. I picked 32GB instead of 16GB. I was trying to get the 64GB at that time but it was sold out.
This head unit comes with all the harness. It’s plug n play on my 2012 civic. The steering wheel buttons work fine.
I replaced the launcher with “car launcher free” because I don’t like the stock launcher. This launcher is a bit customizable. The paid one can let you customize more. I’m happy with the free one.
The reverse cam is also from eBay. We ran the wire from the brake light to the input in the head unit. The night view is working as expected too. The only minor thing is the bracket that comes with doesn’t fit the hole of license plate. We just got a bolt and screwed it in the trim to call it day. So it’s off center just 1” inch to right. No big deal. If I could find a right bracket on eBay in the future, I could redo this minor part. The most importance is the reverse camera is working as expected.
I’m attaching some screenshots from my eBay so others can reference it.
That is very cheap and seems like a good deal for the head unit. My concerns are does it lags/freeze and how do you connect service to it for maps/music, etc, Thanks for sharing this!
Same question. My hesitation to go to an aftermarket unit was that I often use the steering wheel controls and iMid. If that all works this becomes far mo
@VerzerrungThat is very cheap and seems like a good deal for the head unit. My concerns are does it lags/freeze and how do you connect service to it for maps/music, etc, Thanks for sharing this!
The paint job was good. I mean that is not Macco cheap paint job on the taxi. It cost some $$$ when I have refinished the left rear passenger door side because I had them fixed other paint problem. When I got a quote to refinish the right rear passenger door, price was a bit expensive than other shops. I prefer using the same shop but the price isn’t ideal. I’m trying to see if other shops could get the similar result with less $. But I’m worried that with using two shops, the color on left and the right side will be off due to certain facts like different paint materials or paint techniques.If the last place did a good job I would return to them. Simple as that
