Honda-Fan
Are there specific games you’re wanting to use this computer for? That will usually determine what graphics card would be best suited
I mostly play RPGs.
what internet speeds do you currently pay for? That will determine what models would not be a good fitWhat kind of router is everyone here running? Looking to add a new router to see if I can help stabilize my wifi. Was looking at a mesh system but don't think it's necessarily worth it for our size house. All opinions are appreciated.
You happen to have any cat wiring that would allow you to run something like ubiquity access points back to the current router?Gigabit
Thanks. What kind of internet do you have now?I use a Netgear CM600 Gigabit Modem and a Netgear AC1750 'Nighthawk' Router.
If you have the ability to run a cat cable to wherever you’d like better access, the ubiquiti access points work essentially like a mesh router. It’ll pick up and hand off connections to other access points or the router. So you could put as few or as many of their access points in the house and roam on one ssid without dropping connection anywhere. I’d say just get the ac lite as the 5ghz channel can basically do gigabit. If you have to get 1 gigabit, you can opt for the ac pro which does 1300 megs in 5ghz.Not on hand I could probably get some.
So with those you don't have to add anything other than that?If you have the ability to run a cat cable to wherever you’d like better access, the ubiquiti access points work essentially like a mesh router. It’ll pick up and hand off connections to other access points or the router. So you could put as few or as many of their access points in the house and roam on one ssid without dropping connection anywhere. I’d say just get the ac lite as the 5ghz channel can basically do gigabit. If you have to get 1 gigabit, you can opt for the ac pro which does 1300 megs in 5ghz.
https://help.ui.com/hc/en-us/articles/360008036574-UniFi-Access-Point-Comparison-Charts
You keep your current router (or any router) and you run a network cable from the router to every one of those access points. They’re usually found in commercial applications like hospitals, hotels, warehouses, large retail/businesses. They make a lot of commercial networking products as well.So with those you don't have to add anything other than that?
Ok I went ahead and ordered the pro one. From what I could tell the range is enough to cover anywhere in my house from a central spot.You keep your current router (or any router) and you run a network cable from the router to every one of those access points. They’re usually found in commercial applications like hospitals, hotels, warehouses, large retail/businesses. They make a lot of commercial networking products as well.
