i love how it tells you to check tire pressure but
Tony-si
209
16
Van Nuys, Ca
Civic SI
coupe
dont you think it would be cool if it let you know what tire or tires? i know you can look but it would save time. i got that warning tonight. guess what im doing tomorrow =)
When it tells me my tire pressure is off it makes sense to me to check all four. But that’s just me. I’m glad they have a system that doesn’t require extra sensors in the tires.
i look at all tires too but with technology today you don't need more more sensors in tires.
I replaced my head unit and used a maestro rr and it shows tire pressures from factory tpms sensors on my kenwood
Sent from my ONEPLUS A3000 using Tapatalk
I kinda agree but now it depends on which model... wifey has a 2012 civic and it has the tpms sensors while I have the 2015 and honda got rid of the sensors and now uses the abs ring. So... the new way the sensor is less picky and I can easily run different rims or different pressures (lower pressures) without a tpms light on. If honda did add that technology it will also add to the price of the civic, maybe like another $1.5k cause its the stealership haha
I have seen external sensors that screw on the valve stem and you have a little screen that tells you each tire psi, thats an option
