awesome!Thanks guys, ordering the full kit from trs now![]()
Okay this is really looking too good to be true, unless I am missing something. Am I correct in understanding that the projector is only held on by a lock ring behind the headlight housing? No dremeling or screws or anything like that that I've seen with lots of other retrofits? And if that is the case, do your headlights bounce or is this a strong enough way of mounting the projectors that you don't have to worry about that? I had planned on buying an extra set of headlights and doing a retrofit as my winter project, but it's starting to look easier than I was expecting. Any clarification on this is much appreciated.
just the lock rings are used. no dremel or cutting requiredOkay this is really looking too good to be true, unless I am missing something. Am I correct in understanding that the projector is only held on by a lock ring behind the headlight housing? No dremeling or screws or anything like that that I've seen with lots of other retrofits? And if that is the case, do your headlights bounce or is this a strong enough way of mounting the projectors that you don't have to worry about that? I had planned on buying an extra set of headlights and doing a retrofit as my winter project, but it's starting to look easier than I was expecting. Any clarification on this is much appreciated.
Wish I saw this before I ordered mine lolUse TRSTEN for 10% off.
If your have any further questions don't hesitate to give me a call at TRS(Jamel)
Did you pull the projectors solenoid wires through the inside of the project and run the wires past the bulb like this? Or will this burn/ melt the wires?
Ya. In the instructions AP said to pull the wires through the projector and there wasn't any pics or further details. Wanted to double check before I went any further but decided not to run the solenoid wires so they're tucked away inside the headlight housingIs that coming out of the bowl, like through the same hole the bulb goes in?
exactly the same as the low beam spot. Just threaded through the bulb hole.Guys I was wondering, if I wanted to do a quad bi-xenon setup with a projector in the high and low beam spot - would a projector mount just like this in the high beam spot? If not, how would you mount a projector in the high beam location?
