Loppysaurusrex
- 65
Looking for something clean for both my headlights and foglights, preferable like the white headlights you see on most luxury cars like acura's, lexus's etc.
But what is legal?
But what is legal?
Can I just pop in an HID white bulb and that's it or do I need other stuff?60w on high... 55w on low
Lots of different brand bulbs.
Since you said white light, I won't get into why to stay away from colored bulbs(burn out faster, and color filters out distance).
http://oppositelock.kinja.com/headlights-explained-1262237738
So I can go get white halogens and they'll be legal? And I won't need any other parts than the bulbs?HID bulbs will require a kit (harness, ballast, etc.). You really should not use a HID in the stock reflector housing. The light becomes very scattered and can blind other drivers. If you want HID's look into retro fits, or swaps for new headlights with projector housings. If you want the easy solution just go to the local auto store and pick up high output halogen bulbs. They will burn out faster from higher heat and other reasons but it will achieve the desired look.
While there are laws that regulate the light output, the ones that will get you in trouble are more about color. If your sticking with white you should not have an issue.
White is fine. They will last a few days to a few years. You never really know.So I can go get white halogens and they'll be legal? And I won't need any other parts than the bulbs?
How long you reckon they'll last?
How long you reckon it'll take me to switch them out myself?White is fine. They will last a few days to a few years. You never really know.
Don't feel like paying 100$ for a mechanic to do it
What about fogs?5 mins
30 min. Take a look in your manual but its really easy. The high or low, i dont remember which you can do just by popping the hood. The other one is behind the battery on the drivers side and the windsheild washer filler on the passenger side. still not hard, just takes a few extra min. Once you have access its a matter of disconnecting a harness, twisting out the bulb and reversing the process with the new bulb.
What about fogs?
should also be in your manual but,
1. remove the front bezel with a #3 phillips head screw driver
Or do it the hard way like I did the first time...from behind.![]()
removed the clip and reached in. I have small hands, but it was still a tight fight and frustrating.ouch. did you drop the whole bumper or just jack it up and go in from under the bottom panels?
