Note: this_feature_currently_requires_accessing_site_using_safari
Whats the best option for the high beam bulb then? Any suggestions?Its not recommended to run HIDs as the high beam since HID bulbs need a few seconds to warm up and trying to flash your highs, if needed, won't work very well with the HID bulb. Also the DRL circuit runs at half watt/voltage so you would have to pull your DRL fuse and run with the high beams on or off all the time. You can't run HID bulbs at half wattage.
So yes, you can but eh, you lose your ability to flash and no DRL.
I'm looking for more output for sure. I had a Jeep Wrangler with led headlights and loved them. I had an 08 civic with HID's I liked. Basically looking for more output and more white in color.Leave em alone or just get upgraded bulbs. Are you looking for more light output or just to change the appearance? An LED bulb may be a better option than an HID setup but they generally don't have enough light output to be used for driving. Just an appearance upgrade with those.
I use my high beams almost everyday.Do you use your high beams or are you just wanting your drl to be a different color?
nix posted a solution. Pull your daytime running light fuse & run the hids in the highs. You just won't have a daytime running light, and you can use hids in the high beams. It's just not good to flip them on/off fast or flash them, as it takes a few seconds for the bulbs to fully ignite and produce full output.Anyone with a solution?
...the DRL circuit runs at half watt/voltage so you would have to pull your DRL fuse and run with the high beams on or off all the time. So yes, you can but eh, you lose your ability to flash and no DRL.
I heard that when you pull the fuse it will display a light on the dash.. Is that true?Yes.
not sure what else you are looking for. Run the HIDs in the high beams if you want.
