Just got back from the dealership from an oil change. When i went to pick up the car, they showed me 2 things.
1. Two of the techs there recommended i switch from 0-20 oil to 5-20. More pressure in the engine from the supercharger is causing small oil leaks coming out of the valve cover and oil pressure sensor. They said the slightly thicker oil will solve that. So just wanted to put that out there for all those going with boost kits.
2. More seriously, I have a slight leak coming from the trans axle. More torque + stiffer motor mount caused it most likely. Parts and labor they quoted me $264. Not sure what I'm going to do about that one...
