Pauly99to17
Our car wash is $2/3 minutes with a wand. I usually go and pay $4. I control where the water goes or does not go. Better that way.
Very nice job. Well done.
Dar-Dar - Where do you have your catch can mounted. I'm looking to get one and am curious to know where you located yours as it's pretty tight in there.
FTSEvan - Love the wheels. Had the same ones on my DC5. Looks great
While this wasn't a today project, it was a weekend. It did get installed today.
Went from this To this: Red Microfiber/Black Leather
My first attempt at reupholstering anything. I think it came out well enough.
The leather needs to settle a touch, and might need a little more "massaging" but I'm pleased.
Only thing I wish I did different was get the top most panel in black not red.
And that the Si sat a little lower, closer to the stock location, but that was beyond my control.
Modeled after the 14's interior so I guess it works.
The white Si looks nice with all the white text on the inside.
And very comfortable to sit on![]()
Where did you get those ramps? I've seen something similar at Walmart but I'm nervous with them being plastic. It holds up well?I washed my car. It was on ramps and I sprayed the undercarriage with a foam gun. I'll be doing an oil change later on.
They hold up really well. I've had a set for like 10yrs. You can get them at auto stores, Walmart, Amazon etc. They're extremely solid. I use them all the time for oil changes and even washing the car. I'll roll it up on the ramps and claybar or clean the lower bumper without having to be down on the ground. A little rolling seat is great with the ramps.Where did you get those ramps? I've seen something similar at Walmart but I'm nervous with them being plastic. It holds up well?
rated to hold 16,000 lbs.
You'd need about 5-6 civicsThat's a lot of vehicle. I'd hate to be the guy that finds out the weight limit the hard way.
