stock suspension doesn't have camber adjustments. You need camber bolts up front and camber arms in the rear to adjust it.
Front and rear camber kits are definitely needed there.
Figured as much.
I was hoping the stock center caps would fit, but it appears they are slightly bigger. Looks like I have to make my own or buy the xxr center caps.
I think with the 215/40 and a drop you will be fine. Here's how my car looks with 245/40's. I'm thinking of keeping it this height and just adding maybe -1* camber up front and maybe -2* in the rear so I can tuck the wheels in.
Speaking of camber.. Anyone know the max camber I can get from the stock suspension?
That rear end poke though
Did you use camber kits on your 8th? It looks like your 527s have much lower offset than the set on your previous car.
. I have two jackstands under the car and the jack supporting the car. The car is not touching the wheel at all. I just like to throw it under like that as another safety precaution incase my jackstands slip or breakHaha everyone that has seen this pic has asked me that. No it's not. I have two jackstands under the car and the jack supporting the car. The car is not touching the wheel at all. I just like to throw it under like that as another safety precaution incase my jackstands slip or break
the rest is coming on TuesdayFront HFP lip is coming in on Fridaythe rest is coming on Tuesday
. Debating whether or not I should order the side molding for the door
You're only getting the front lip?
But the HFP side skirts are so nice! Especially compared to the other options out thereI only have the front and do not intend to get the others. You have a problem with that?![]()
