downpipe with stock exhaust
Oh and are you buying off there website or did you find a dealer to buy from.
That's the only reason I wanted the short ram haha easy install and no battery relocate [emoji51]
It is a bit of a tight fit and does not have a bracket to hold the tube in place. At first the filter was hitting someplace towards the firewall and rattling. So, I removed a bracket from the stock airbox that allowed me to lower it, but that causes the filter to sit on the shifter cable brackets.
Ill see if I remember to put in a DIY when in comes in. But now I have to buy exhaust gaskets and a defouler because I forgot to order one.
I went through the same thing, removed that bracket but it was still rubbing, so I angled it high, almost touching the plate running between the struts, and tightened the hose clamps as much as possible. It's been sitting fine for months now.
