Anyone running carbon headset spacers? Mine came with them and I think they are a reason for my front end creak I've been getting. And after my tumble, it got a bit worse and they are definitely a little looser, so I'm going to try a good set of aluminum ones. Any recs?
I've seen some reviews of carbon ones, indeed causing some noise issues.
They aren't that much lighter than aluminum ones. Try just loosening everything and recoating them and using carbon specific grease on the dynamic surfaces , the places where they touch, and see if that doesn't help.
EDIT: If the noise doesn't go away try a stack of aluminum spacers. Decent shops should let you switch and test in the parking lot for free. Depends on the store though.
EDIT X2: I had the same problem and switched to an AL stack. The grease ended up being the culprit. Some carbon "grease" is a fiber composite that grinds a lot. Until the fibers break down it makes noise. Just depends on what's been done or not done.
I've been out of mountain biking for a while (10 years or so). I'm not looking to spend a lot (I'm cheap) and also because I want to start slow and get back into it.
