Alrighty... soHi,
I am new when it comes to retrofitting my 2012 civic. I am planning to change my projector headlight and i've seen that you guys have already done it. Im planning to install this item(http://www.procivic.com/pages-product_car_part_info/product-1129:2e81a202b331e4531a705f34cb84d79d/index.html), and since some of you folks have done it already, I just have some few questions. Do I need a warning canceler(http://www.protuninglab.com/hiderwacacax.html) if its HID in this kind of projector headlight? if theres no warning canceler, will the HID workout fine or there might be some flickering or worst case not turn on at all? Can i still put a 9006 HID bulb in this kind of projector headlight? Or only H1 bulbs fit in this type? With regards to the HID ballast-- how hot does it get? Im just concerned if the ballast would get so hot that it might melt the zip tie that I will use to secure it, or melt the plastic its mounted on(if ever I see a spot where its plastic and can be mounted)? A little shed of light will be much appreciated. Thank you![]()
1. You can put HIDs in that housing
2. You will not need any warning canceler
3. You will need H1 bulbs
4. The housing will not cause flickering
5. I mounted my ballasts on metal, using the included 3M tape, and it's held fine so far
