- 56,718
- 24,144
nice work, images backed up
Those 4 washers go on one end (to the chassis). The other end that connects to the flange need 4 additional washers. So you should have 8 washers in total.
I don't think they are taking this issue into account. I posted this porblem on 8thcivic and on fb.
So... 16 washers for both arms?Those 4 washers go on one end (to the chassis). The other end that connects to the flange need 4 additional washers. So you should have 8 washers in total.
What type of noises were you hearing or when so i can keep a look out an catch that.
Your arms don't creak in this cold weather?
When did you install the washers for the bottom bushings?I used metal washers and mine are squeaking like mad. It's 30* here. About 6k miles on the arms
have you found a good bushing replacement yet?When did you install the washers for the bottom bushings?
6k is a lot of miles. Your bushings might be done. Mine were around 1.5k miles before I threw them away.
The last set of bushings I found were getting overcompressed and didn't fit the bracket. I'll be shaving off 1mm per side using a dremel to see if that will do the trick.have you found a good bushing replacement yet?
mine have a lot of miles on them now too and have been squeaking a lot more now with the cold
Yeah, may even be more. I drive 2 hours a day for work. Sucks.. I'm not impressed with them. Or sportline springs. May spend the money and buy buddy club arms (they look quality)? And some coilovers.. IdkWhen did you install the washers for the bottom bushings?
