his avatar....
pretty much everyone has said 2" and over...it will not be in spec. Numerous have posted their alignment spec sheets before/after.
thats odd...mine was fine after a toe adjustment. i wish i took a picture of the specs. i can next rotate when i check it.The H&R springs had my rear camber all effed up and its only 1.4 in the rear. I wouldn't say it stays in spec everytime the time.
Why would i need the camber kit?Be sure to pick up some Godspeed rear camber arms![]()
So will i be good with just the skunk2 drop springs?mine is 1.4 then aswell. H&R springs here too....mistype up there on drop, sometimes i have wishful thinking.
your car will be out of spec after dropping it 2+ inches. The camber kit will help you correct it. Otherwise, you'll end up with uneven tire wear.Why would i need the camber kit?
i can use these springs with my factory shock absorbers and experience no problems?your car will be out of spec after dropping it 2+ inches. The camber kit will help you correct it. Otherwise, you'll end up with uneven tire wear.
