Hillstones
It is necessary to remove the rear seat side panels and the molding that covers the airbags before removal of the rear deck is possible due to the way everything interlocks.
From what I have read so far, there are no direct fit tweeters either. So that means a bit of custom work...probably just drilling new holes. It would be best to buy a component set for the front as 9thgizzyguy mentions in the thread Phaheem referenced above. If installing an amp to connect them to, it would be necessary to run wire from the amp to the front speakers as well as installing the new crossover and running the wires that the speakers will connect to.
This really isn't a job for the faint of heart.
Yes, there would be quite a few panels to remove in the back, but I am sure any experienced stereo shop would be familiar with doing that kind of work. I usually like to do my own stereo upgrades, but with the way the premium system is wired, I might want to leave it up to the pros so I can get a good sounding system. I don't want something booming, but I do want clean solid bass and clear highs with a good set of components up front and good speakers in the back, all run through an external amp while keeping the Navi head unit. It is not uncommon for the Honda pillars not to directly accept an aftermarket tweeter. Usually there is some type of custom work needed to be done to get it to fit and look good. That is what a good stereo shop would specialize in.
