Fuse Tapping Not Working as Intended
Velox
48
90
Naples, FL
2013 Civic EX
Hey there,
I'm new to this forum and to owning a Civic. I plan to introduce myself in the intro section after I finish a few more things with my new car.
However, I'm encountering a problem with wiring my LEDs. I'm using the fuse box to avoid splicing into any wiring for the sake of my warranty (I can undo a fuse box installation fairly quickly if I need to take it in or something) but I'm having a hard time wiring it so my LEDs only have power when the key is turned.
I have tapped into fuse 12, 27, and even 11 (front acc, middle console acc, and moonroof) in attempts to only gain power when the key is turned. However, my LEDs are still drawing power from these fuse locations when the key is not turned. The actual accessory is not, though - only the LEDs are drawing power. For example, when tapped into my moonroof fuse the key still must be turned for the moonroof to work, but the LEDs will draw power out of the same fuse port when the key is not in. This may be completely normal but I'm rather new to fuse boxes and may be overlooking something simple. I assume I'm doing something incorrectly because my hardware appears to be operating correctly. I am using an "add a fuse" device and it's plugged into the fuse box how most guides demonstrate.
I'm rather new to working on car electronics but other hobbies have taught me a good amount about wiring and electricity in general. I've read many guides on how to wire LEDs but I'm still missing something that is really going to create an inconvenience.
Any help would be great. I've tried experimenting with various options trying to make sure I'm not forgetting something, but I'm hesitant to try too much in case I damage my wiring or any active circuits.
for example....
the one top the top is the priority then followed by secondary in which you can add a larger fuse ampacity :)
i think you might have been tapping things before their switches in the electrical system, i dont have a 9th gen wire diagram to be sure but that could explain why you were getting constant power
I was not expecting so many helpful posts so quickly. Thanks, guys!
Fuse #23 bro :) and make sure you're using each fuse slot on the tap in priority order of wiring :)
I used fuse #23 and it worked just as I hoped - I'm only getting power when the key is turned. Thank you for the suggestion.
certainly :) It's ignition powered :)
If you'd like, you can use another slot, but you'd need to add a main power switch to turn off everytime lol
Anyone know the fuse that is on when the door opens, but turns off when the key is turned to on->ignition?
Engine compartment
■ Circuit protected and fuse rating
Circuit Protected Amps
1
EPS 70 A
ABS/VSA Motor 30 A
ABS/VSA FSR 30 A
Main Fuse 100 A
2
IG Main 50 A
Fuse Box Main 60 A
Fuse Box Main 2 60 A
Headlight Main 30 A
Rear Defogger 30 A
Blower 40 A
Sub Fan Motor 20 A
Main Fan Motor 20 A
3 − −
4 Left Headlight Low Beam 10 A
5 Starter DIAG, ST MG 7.5 A
6 Right Headlight Low Beam 10 A
7 − −
8 − −
9 − −
10 − −
11 Oil Level 7.5 A
12 Fog Lights* (20 A)
13 Driver’s Power Seat Sliding* (20 A)
14 Hazard 10 A
15 FI Sub 15 A
16 IG Coil 15 A
17 Stop 15 A
18 Horn 10 A
19 Premium Amp* (20 A)
20 INJ (15 A)
21 IGP 15 A
22 DBW 15 A
23 H/L LO 20 A
24
Driver’s Power Seat
Reclining* (20 A)
25 MG Clutch 7.5 A
26 − −
27 SMALL 20 A
28 Interior Lights 7.5 A
29 Backup 10 A
Interior
1 − −
2 ACG 15 A
3 SRS 10 A
4 Fuel Pump 15 A
5 Meter 7.5 A
6 Power Window 7.5 A
7 VB SOL* (15 A)
8 Door Lock Motor 2 (Unlock) 15 A
9 Door Lock Motor 1 (Unlock) 15 A
10 − −
11 Moonroof* (20 A)
12
Accessory Power Socket
(Center Console)* (15 A)
13 − −
14 Seat Heaters* (15 A)
15
Driver’s Door Lock Motor
(Unlock)* (10 A)
16 − −
17 − −
18 − −
19 ACC 7.5 A
20 ACC Key Lock 7.5 A
21 Daytime Running Lights 7.5 A
22 HAC 7.5 A
23 − −
24 ABS/VSA 7.5 A
25 − −
26 − −
27
(Front)
15 A
28 Washer 15 A
29 ODS 7.5 A
30
(Lock)* (10 A)
31 − −
32 Door Lock Motor 2 (Lock) 15 A
33 Door Lock Motor 1 (Lock) 15 A
34 Small Lights 7.5 A
35 Illumination 7.5 A
36 − −
37 − −
38 Left Headlight High Beam 10 A
39 Right Headlight High Beam 10 A
40 TPMS* (7.5 A)
41 Door Lock 20 A
42 Driver’s Power Window 20 A
43
Rear Passenger’s Side
Power Window
(20 A)
44
Front Passenger’s Side
Power Window
20 A
45
Rear Driver’s Side Power
Window
(20 A)
46 Wiper 30 A
It may be #28 under the hood... or #34/35 inside the cabin.
I tested fuse #35 but there's no power when the door is open and no key in the ignition. Here's what I'm planning on doing: I bought ebay illuminated door sills; I'm planning on tapping fuse #14 with add-a-circuit, and then tap into the ground(green) wire in the door jam button so it turns off when I close the door and turn the key. I tested with a multimeter and it seems to work, but I wanted to see what you guys think. Thanks.
not sure i would go this route... i would do the same as user amomcivic did and make it so that ground is switched. since in DC power when you cut the ground, power is taken away because you lose continuity.
just my 2c tho :)
just my 2c tho :)
I see where you're going with this. So basically if the ground is cut, power to fuse #14 will be cut also? What if I tap into one of the empty fuse slots like fuse #13? But the slot is crossed out on the diagram so I don't know what amp fuse to put in there. Any ideas? I'll look into the switched ground.
Anyone know how to figure out what amp fuse to put in these fuse slots? I tested them and there is power.
*Pic is from another user on this site*
All depends on how much power the items are using. Do you have a list of how many bulbs/wattage each one is rated for?
I don't, I just bought them from ebay. They look like authentic door sills that illuminate on all 4 sills. They are just leds that need to be powered. I'm thinking 7.5-10 amps should be ok?
That looks good! I'm guessing 5 amps would suffice since the 2 back sills would probably draw the same amount of power as the front 2 sills?
