Dtexan
At work we purchase the T430s laptops they are built like brick s-houses and priced reasonable. With an SSd installed they are very fast machines.
yeahhh it's all for the benchmarks!I've backed my 3770K back to 3.7GHz from 4.2GHz. I'm not seeing it unless I'm using the processor to do math operations. But I'm not doing that all the time and when I really need it, just use the high performance computer I have access to and spread duties over 72 3.46GHz Westmere cores.
well... 120/240ssd primary, with 2tb wd cg hdd would be cool as secondary. i'm running a 1.5tb green right now which is 64mb cache, 7200rpm sata 6gbit and 120gb mushkin chronos deluxe primary, and it's rolls like a bossWhen go SSD, HDD is no longer an option.
Still loving the Sandy Bridge series. My 2600K used to be at 4.9 Prime stable, figured the temps weren't worth it (this was before I got water - temps were a bit high...) I keep it at 4.4-4.6 (4430 right now) depending on the day. Definitely notice a difference in games where the processor is the limiting factor by bumping it up (sure isn't the SLI GTX680 Classifieds limiting it!)
yeahhh it's all for the benchmarks!lowered mine to 4.40GHz right now on i7-960
idle temps are less than 23c and load doesn't get much about 28c
Got to over 40c at 5.1GHz with HT on :p
What liquid cooling do you have? Definitely not just a closed loop with those temps @ that speed.
what ram you running? i have my air cooled patriot viper xtreme set running 2300MHz @ 1.67v 6-7-6-20-1T on all 3 modules when in bench mode(12GB total)I want to put a ssd in my macbook pro, but im waiting for drive prices to come down so i can get at least a 500gig since i want to keep my optical drive.
The comp has 16 gigs of ram in it already, a SSD will make it scream
yeahh :/Im running G.Skill DDR3 1333 2x8gig. Since its on a mac its running at whatever speeds the computer chooses since i dont think apple lets anyone tinker
Yeah I'm not a benchmark freak. As long as I can play BF3 I'm happy![]()
I took my h100i off and put the 212 EVO back on.
66C Max with the h100i (setup as exhaust exiting out the top of case)
71C Max with the 212 EVO (push/pull config)
The 212 EVO is much quieter than the h100i. I just need to configure SpeedFan so that I can control the fans via Windows instead of via the Bios.
You have those fans on the H100i at full power? Like a jet engine. Turn them down and it's much quieter. I'm fixing to get some quiet fans.
I did turn them down. Had 'gaming' mode when I was playing BF3 which used the Corsair Link 'performance' mode settings. I had a 'Base' mode when I was just whoring on the forums which used 'quiet' mode via the Link software and I also had an '800RPM' mode.
It was quieter of course at 800 rpms but still for the 6C difference between the two (for now) its not worth it.
$30 vs $90 (I got it on sale - normally $110-$120)
71C vs 66C (@ full load)
I'm doing testing now. I might switch back to the h100i and get some new fans but I don't know. Not worth it as of now in my eyes.
I'm OC'd to 4.2Ghz BTW.
