Official Quickest Quarter Mile Times
did you get your dyno done?
Could not her my scanner to work
Car:421
R/T : 0.573
60' : 2.345
330 : 6.440
1/8 : 9.738
MPH : 75.15
1000 : 12.560
1/4 : 14.941
MPH : 94.73
I think I need a better clutch and some tires
Mods are
Full race cat back
Hondata reflash
Resonator deleted
K & N drop in
Sent from my MB865 using Tapatalk
Mods you had when you ran a 14.7? I see from another post you may have the Injen CAI & Full race catback?
great stuff
IMAG0446.jpg last run was 14.826 with reflash and exhaust. This run I added injen Cai. Temp was about the same but much more humidity, track seemed slicker than my last runs
did 14.47 on stock car, the only i did was remove my sub and extra tire in the trunk of my car, temperature was 13C and i did power shifting, my worst time was 15.10, i did about 4 runs of 14.70 and one of 14.9 with my girlfriend inside the car. i have a video with my cellphone but it is blurry and at night which sucks.
only modification i have done to the car is plasti dip my wheels, calipers and the intake manifold...i havent done anything to increase hp. I used 94 octane gas and i went with a little bit less than half tank. hope that helps for people wonderingIMG_0214.JPGIMG_2765.jpeg
Here are all of my runs.. my car number 45 as display on the picture above as well.
I was launching between 3000 and 3500 rpms on stock tires, i did not look at the pressure on my tire.
View attachment 15875View attachment 15876
What track was this. No offense but I think they need to calibrate the clock. Running mid 14s with 2.3 and 2.4 60fts is insane. Those are terrible 60ft times. And it happens with street tires. But also trapping 96 mph. Your car must have 200hp at the wheels stock. The numbers just don't add up for a stock car.
I know you're gonna get pissed but whatever. Not trying to start an argument. Just saying those numbers are crazy looking with that 60ft time.
Here is mine 2012 civic si coupe with k/n drop-in filter, flashpro. Launch bout 3300-3600rpm, full throttle until 7400rpm, my first try with this new Si, temp outside 55-60f, im still trying to get feel for it.. I believe i can get 14.4-14.7@95-97mph if launch higher with better tires on, and soimage.jpg
st thomas race way about 15 to 20 minutes from london on canada. i was suprised as well, last year when i went i could only do 15 flat my best run... this time like i said i removed my tire in the trunk and sub. now you gotta count the weather too, 13c helps alot the engine was cool... I will be going back to another track in 2 or 3 weeks and let I will post how i do
by the way i also went with less than half tank of gas on 94 octane
