immajackuup
22mm progress rear sway bar coupe si
don't know,moog heavy duty. bought it from redshift.Very nice! Which end links are those? I see it says Moog on them and the box but, any particular one? model #?
yes,handle well but do need a bigger front sway but not big as rear..have you taken it for a spin yet?
just found out they are 18,i probably don't need front sway.What's the size of the stock front sway bar?
rear is 15 on si and ex is 11believe it's 15mm
front bar is 18 and rear is 15. on front wheel drive car bigger rear swaybar is better.The front sway bar is 15mm or 18mm? I thought the front sway bar is supposed to be bigger than the rear.
No need to google it. You just gave the info.front bar is 18 and rear is 15. on front wheel drive car bigger rear swaybar is better.
best to google for more info..
____________Very nice! Which end links are those? I see it says Moog on them and the box but, any particular one? model #?
_______________________
Did you ever look up the detail on those Moog end links?
