Contemplating real bright LED reverse lights, on a semi-DIY basis. Thinking 2 of these 7 LED assemblies:
http://www.luxeonstar.com/Neutral-White-4100K-7-LED-CoolBase-Assembly-p/sr-02-wn300.htm
1610 lumens @ 700 ma drive current, since it's relatively short duration use, I see no issue with cooling, even with a small heatsink.
2 of these 12 degree collimator optics:
http://www.luxeonstar.com/Polymer-Optics-7-LED-Cluster-12-Optic-p/261.htm
Two of these LED driver modules:
http://www.luxeonstar.com/700mA-Externally-Dimmable-FlexBlock-Driver-p/a011-d-v-700.htm
And two of these heatsinks:
http://www.luxeonstar.com/40mm-Round-Alpha-Heat-Sink-p/cn40-15b.htm
This would be a fairly expensive project, but let's face it, have you ever had too much lighting while backing up? I pulled back the trunk lining today, measured up the diameter of the through hole in the body, the outside dimension of the reverse lamp portion, and so on. It looks like it will fit fine with no need to cut any metal, just the tail lamp rear housing.
If you can solder, use a dremel tool or other, a hot melt glue gun and use a test light to identify the correct wire polarity and splice wiring, you could do this mod without any issue.
I know a 12 degree beam isn't very wide, but the stock lens will help spread that out. If it were clear, from my angle calculators and lumens / lux calculator... a 22-25 degree beam would be mint.
http://ledstuff.co.nz/data_calculators.php?osCsid=evocmopzepnozrsa
Entering the raw lumens, and the 12 degree beam, with a perfectly clear optical lens, you would still have 4.678 lux at 100 meters ( 328 feet ) with a 21 meter diameter coverage pattern!!!! That is SICK!
Edit: might have to include a wire to a switch in the front for those idiots that feel the need to follow you at 2 car lengths with their high beams on.....
