- 57,153
- 24,330
public pricing
oem bumper cover - $269
oem fender $141
ripoff
oem fender $141
ripoff
public pricing
oem fender $141
ripoff
ahhh yes, canadian pricing would probably be different. Those were US prices I posted
I got the quotes today. $2700. Bumper, headlight, fender, alignment, the paint and labour. They will keep the car for 5 days.
Yep. Zero deductible is because it was a hit and run. A normal collision is a $500 deductible.
Note to self: Ask the hitter to leave. jk![]()
Thanks guys. I always park far in parking lots but when you're visiting and have to park on the street what do you do? You don't really expect to get hit there.
It's just a pain getting quotes and finding a half decent repair shop. I'll start at the dealer Monday I guess.
5 days? That's ridiculous... in the shops I worked it, that would show up at 8 am, and be ready to deliver for the next morning. Wash car, remove bumper cover, fender, hood and headlight, send it to the mechanical side for an alignment while the inside of the hood and fender were being washed, scuffed and 'jammed'.
Even without baking capability, with BASF DC76 'turbo' clear, you could have the inside of the hood and fender shot and ready to bolt on in about 2 hours tops. Bolt on the hood and fender, prep the hood outside and fender outside, sand back the damaged paint on the bumper cover and prep the rest with Glasurit Sand-fix paste and a grey scotchbrite.
By mid afternoon, it would be taped, in the booth ready to spray, since you would have already sprayed a let down panel when jamming the parts to get a good idea of how many mid-coats you need if it's a tri-coat color. ( Ground coat, mid coat with pearls and then the clear coat ) If it's a simple formula, you can adjust if if need be.
If a tri-coat, the ground coat must be a match, as well you must match the amount of mid coats, as each progressive coat will change the look ( obscuring the ground coat more and more )
Install the fender liner, tire, remove masking materials, wash car, vacuum and deliver to the customer. In a shop with baking capability, or the latest UV cure primers and clears, this would be an even faster repair. 10 am the next day wouldn't be a problem to deliver.
Just be careful your insurance rates don't go up.
Had a similar situation in the past. Was using esurance at the time. explained to me that I was home and parked and there were witnesses and what not so rates wouldn't be affected. I don't remember the specific amount, but at renewal rates would've went up around $100 per month with them. That's when I switched to progressive and never looked back, who only charged +/- 10 what my previous esurance rate was.
Sucks though either way.
AH nuts! I'm late to see this Andre. Don't know how I missed it. Man, I feel for ya.
The bumper may just need pushed back in that area to catch the tab. If it is all the way in, the headlight bracket may need adjusted.
