2012hondakid
so i have my line out converter....so do they jsut connect to the postive and negtive wires in the speakers and the ground wire to the ground wire to the amp?
Just connect the positives and negatives of the LOC to the negative and positives of the rear speakers. Grounds do not need to be used unless you get noise in the signal, and then you would ground them to the car ground or amp ground. My ground wires were not used.
Cool. Post pics!alright thanks im going to install it tmrw
alright thanks will deff have pics up by wednesdayThat's what I did. Just tie into the fuse panel into a switched source. It won't draw any amps its just for a remote.
They pretty much hook up just like you explained. I have never used that LOC but , I did positive and negative then RCA to amp. Oh and welcome !Hate to jump in here but I's like to add in with a question. I'm looking at getting an NVX XPLOC2 LOC, do I have to connect all the wires or just the positive and negative to the rear speaker wire? A note, first time ever trying a LOC
