- 24,332
Honda Fit Shuttle goes on sale in Japan
Honda has launched a new compact wagon in its home market of Japan. Called the Fit Shuttle, the mini MPV comes in two flavors; the Fit Shuttle 15X and the Fit Shuttle Hybrid. The 15X gets its name from the 1.5-liter i-VTEC motor under the hood, which returns nearly 44 miles per gallon using the Japanese 10·15 testing procedure, which matches that of the standard Fit. If you desire even more fuel efficiency, the Fit Shuttle Hybrid utilizes a 1.3-liter i-VTEC engine that's paired with Honda's IMA hybrid system. The hybrid will leisurely sip fuel at a rate of nearly 59 miles per gallon using the same test, again matching the regular Fit Hybrid.
Both Fit Shuttle variants are five-passenger people movers that feature a veritable arena of cargo space, relative to the vehicle's compact size. Storage is readily available above the low load floor, but there's more hiding underneath. The rear row of seats can be stowed, creating a flat cargo space. The varying rear end arrangements allow for a wide variety of cargo to fit inside the Fit Shuttle.
Besides the cargo being comfortable, passengers will be entertained by the InterNavi system that's equipped with the Linkup Free system. Utilizing a 3G connection, Linkup Free allows users to quickly transmit and receive data while on the go.
The Honda Fit Shuttle 15X starts at 1,610,000 Yen, or about $19,943 U.S. at current exchange rates. Pricing for the Fit Shuttle Hybrid begins at 1,810,000 Yen, which is around $22,420 U.S.
