k24ManSam
Has anyone installed lightweight pulley's? If so how hard was it? Also, what is the benefit to underdriving the crank pulley and overdriving the alternator pulley? Is there really good hp gains from this mod?
competiton clutch said:The 2012 and up cars uses a very sensitive crank speed detection system. If the ecu does not see the crank speed up and slow down properly (within what it knows is proper) in between each stage of the 4 stroke cycle (suck, squeeze, bang, blow) it will throw a check engine light and cause the vehicle to go into limp mode.
We have found out that our clutch assembly for the previous gen si's (8037 base kits), when combined with a properly weighted OEM flywheel (22100-RBC-003), will fall within the realm of what the ecu deems as proper and allow the car to run with an aftermarket clutch assembly.
With an aftermarket ecu or perhaps a reflash of the factory ecu you can get around all that and just bolt up a previous gen clutch and flywheel (8037 & 2-800). I hope this clears things up for you.
Thank you,
Dominic F.
Warranty/Tech
Competition Clutch, Inc
so hondata has addressed the issue. I do not know what a pulley would dohondata said:snip....., and it can switch off the misfire codes associated with light flywheels.
Doug
The NST pulleys is what spurred my questions. It doesn't state on their website what the advantage of underdriving the crank pulley does though.
Dropping rotating mass will not "add" power but will "free up" power that is already there.
So are these pullies worth it? Do they jeopardize the reliability of the Honda K24 motor?
