- 56,907
- 24,204
Will your wire harness will work with the h1 bulbs?
The bulb is plugged directly into the balast..so i do t need any comvertion thing..i plug the H1 bulb into the balast and im good to goyeah.. like webby said, a relay harness is always recommended also.. ballasts are interchangable.. so he doesnt have to worry about that..
I had like 10 different sets of hids...and never needed something like thisthis is what I'm referring to -
http://www.theretrofitsource.com/product_info.php?products_id=167
Same thing happened to cheaper relay wiring in my vehicle.I think mine started with issues between the relay and the wires that connect (harness). Water/humidity/weather started to corrode things at the connection.
when I replaced it, I mounted the relay in a better spot, and taped it all up.
Where did you find these? And they dont have to be blue right? I really like the look of these. The blue looks cool but I think that cops are super anal around here about any blue or red lights on your car.I feel like LED strips are getting played out, but at least no one I see has blue......
RX330's w/color mod lenses, gatling shrouds.
In another thread he said customlightz.com did them. They could do whatever you wanted as each retrofit is done to order.Where did you find these? And they dont have to be blue right? I really like the look of these. The blue looks cool but I think that cops are super anal around here about any blue or red lights on your car.
Thanks Webby. Where would you get these installed at or do you have to do them yourself?In another thread he said customlightz.com did them. They could do whatever you wanted as each retrofit is done to order.
