Max spacer thickness?
Michael Perez
154
Miami, FL
2012 Civic Si
This might have been covered before but would you all say 5mm spacer on factory Si studs is the maximum but still safe to run?
Thanks
Dennis Rockholt
9k Alll Day
1,952
869
Franklin, TN
370Z Fairlady aka "Nismo"
I am running 20mm on my stocks and it is perfect. Also, lowered and have had NO rubbing issues
Michael Perez
154
Miami, FL
2012 Civic Si
I mean spacers though specifically how many turns of the lug but are considered safe.
Adapters are the ones that bolt to the hub then the wheels bolts to the adapter.
Dennis Rockholt
9k Alll Day
1,952
869
Franklin, TN
Oh I see. Uhm lemme look for a thread on it, I think there's one
FRDRICE
Retrofit Much?
296
137
ATL
'13 Civic Si
Most people recommend at least 6 turns by hand
Nix
Jötunn Moderator
10,765
8,162
Lew-vul, KY
It's A Fast Pig!
The rule of thumb with lug nuts is that you need to engage as many threads as the diameter of the lug nut. I don't know the size of the 12'+ civic off hand but it's probably12mm & Honda thread pitch is 1.5mm per thread.
You'll need 8 turns of the nut to engage 12mm worth of threads.
8 turns x 1.5mm = 12 mm of engagement
7 turns x 1.5mm = 10.5mm
6 turns x 1.5mm = 9mm
5 turns x 1.5mm = 7.5mm
Take one off and put it back on until it's tight and see how many turns you get. If it's only 4-5 till it's tight I think you might be running a little short. 7? You're probably ok. I'd say get extended studs with a 5mm spacer just to be safe but check it out and see what it looks and feels like to you. 3mm spacer is usually the max you can safely run.
Dennis Rockholt
9k Alll Day
1,952
869
Franklin, TN
:yeahthat:
