Datalog Analysis
323
Modifier
5,252
3,682
Chicago
To anyone that feels up to it, here are two half-hour datalogs that i ran to and from work today, just regular driving.
I'm posting these because ever since i installed my PRL RBC kit, i can drive around fine but every time i go WOT, i get a CEL
P0171 - System Too Lean (Bank 1)
No big deal, i'm guessing because i'm getting retuned Friday. Just thought i'd through these up in the meantime.
http://www.filedropper.com/datalog0000
http://www.filedropper.com/datalog0001
323
Modifier
5,252
3,682
Chicago
links arent working for me.
what tune do you have?
I had a custom tune before I did my RBC swap, then I started using the reflash because I know it runs rich, but I'm still getting that error.
I talked to my tuner, they told me the ecu can compensate but only to a certain percentage, then it throws a code.
But it's alright, I have an appointment Monday now.
soSincerious
Active Member
I would expect a vacuum leak to set a code during idle, not WOT. seeing as how the code only sets during hard acceleration, seems like the tune just isn't quite right. OP confirmed what I was thinking. after the tune you should be good :)
Reactions: 323
