Problem Guy
New Member
I have a 2014 sedan manual transmission and 1.6 liter R16A engine. I am the first owner of the vehicle and have had all the annual maintenance done so far. Also, it has been in about 50,000 kilometers, that is, 30,000 miles. One of the problems is that the vehicle takes the gas at its own will no matter what gear it is in. I press the throttle pedal a lot, it goes a little. When the car was in its early days, I pressed the throttle pedal a little, it would accelerate a lot. Now I press the throttle pedal a lot, but it accelerates slowly, I have to wait for it to come around. It makes me very hard in the city. Also, when I press the econ mode, it appears on the display, but it has no effect on the vehicle or the gas pedal. It doesn't matter if it's on or off. I think the ecm or ecu map is stuck in the economy mode. Also, if I shift up and pull my foot on the clutch quickly, the engine seems to stall. It feels like someone is squeezing its throat and the car shakes a lot. The authorized service can't find any problems. It was said that it could be the clutch assembly and I changed it but my problems still haven't been fixed. Also my old clutch assembly was like new. I gave the car to a relative for compelling reasons and I don't know exactly how he used it but he may have used it a bit aggressively. It's been a few years since then and I have these problems and they are getting worse. What should I do? Please forgive me for any spelling mistakes. I'm writing with a translation program.
