Are you going fast in reverse ? Also it can vary due to cars soundproofing.
It's normal with reverse. It sounds like an RC car.
Yes, the reverse gears are straight cut and the forward gears are helical cut to keep gear whine to a minimum.It's the way the teeth are cut in the gears for reverse that causes the noise... every manual Honda I have driven makes noises in reverse, the faster you go, the louder it is.
For race applications forward gears are straight cut also. Straight cut= strength and ease of construction - helical cut is quiet but pricier to make.Does that car have 6 reverse gear speeds that's backwards?![]()
I know. I was making a joke.For race applications forward gears are straight cut also. Straight cut= strength and ease of construction - helical cut is quiet but pricier to make.
