Who makes a good replacement filter for in the car?
Tony-si
209
16
Van Nuys, Ca
Civic SI
coupe
I know there is a cabin filter and one more. Who makes a decent one as my filters need of replacing.
there are a lot of them-I suggest buying three at a time, some of them are scented too.:shady:
I still use OEM-swap Fram brand filters for everything, since we always seem to have them on hand in Dad's shop. If you'd like a more permanent filter, K&N makes a set for the 9th gen Civic that's pretty nice.
Pros For K&N:
-Permanent, just blow them out with compressed air when they get dirty.
-Better airflow for performance
Cons for K&N:
- More airflow also means more dirt in the engine over time.
Pros for Fram:
-OEM Swap-in
-Better Filtration than K&N
Cons for Fram:
-Not Permanent
-Less Airflow
Cabin Filter #1: Fram CF10134 for Civic 2.4L Si
Cabin Filter #2: K&N VF2001 for Civic 2.4L Si
Air/Intake Filter #1: Fram CA10359 for Civic 2.4L Si
Air/Intake Filter #2: K&N 33-2473 for Civic 2.4L Si
I'm 90% sure these are the right part numbers-- but please double check them before you pick them up to make sure.
Hope this helps!
[SIZE=5]@sunofwolf[/SIZE]
Calm down.
ok, I didn't see you listed both air filter and cabin filter. one point added.
I like using the K&N cabin filter and drop in air filter. Another thing to add is be careful on buying oiled filters as they pollute the MAF and will require constant cleaning.
ok so I installed the fram cabin filter and when I turn the fan on there is a vibration. Does anyone know what could have happened?
Is the filter loose in the frame? Maybe the wrong filter?
I can not see in side. not fit my hand in to feel. should i get a compress air can and shoot it in there?
You can drop it out to look inside and clean it easier. I believe it is only 3 screws that hold it in.
What kind of vibration and where? You could have a leaf in the fan.
I actually had a very similar issue the same week I got my car. I ended up taking it back in and they said that there was debris (leaves and shiz) in there between the fan and filter areas.
I took it out slowly and put the new one in. blah56
