I don't have them yet but......I'm curious to know. Front or rear? Have you greased them? Have you checked to make sure none of the bolts are loose?Has anyone experienced any noise coming from their moog endlinks before? I hope I'm not the only one.
Yes I had chronic knocking noises coming from my rear suspension for a while. A few months ago, I bought some blue loctite, took the endlinks off, cleaned the threads, and re-tightened them with loctite. It's been nice and tight and quiet ever since. The nut had to have been unthreading from all the force it was enduring. So I would start with that before you go replacing them.Has anyone experienced any noise coming from their moog endlinks before? I hope I'm not the only one.
Welcome to the car mod world @KakedoIt's coming from the rear and it doesn't seem as if it was loose. It wasn't like this before I put on my new suspension plus adjusting the shock length of my new coils. I previously had godspeed mono rs and then switched to buddyclub racing spec and i'm like always deterred by all the **** going on with my car.
I know. Had my car since 2013 and I've ran into my fair share of problems from the start. QQWelcome to the car mod world @Kakedo![]()
Since you're going with a 24 vs my 22, and since Progress also comes with reinforcement plates. Stock may work, but I think the Moog has better cushioning to work with the factory made weak area of the mount. I'm doing good so far(for a couple of years), but the Moog is a better way to go.I just ordered the 24mm progress rear sway bar and from what i can tell it comes with bushings and adjustable end links. Should i buy the moog bushings and end links or are the ones that cone with it good? From what i could tell the bushings with the 24mm bar look like the moogs.
Personally I still think the Moog bushings are better and the end links look better quality IMO as well.I just ordered the 24mm progress rear sway bar and from what i can tell it comes with bushings and adjustable end links. Should i buy the moog bushings and end links or are the ones that cone with it good? From what i could tell the bushings with the 24mm bar look like the moogs.
I never did install the plates for the endlinks, which explains the "clunk" noise. I was in such a hurry at my friend's shop trying to get two projects at once. I'll install them this wed. and see if that solves my "clunk" issue.The reinforcement plates are necessary for the endlinks. The backing plates are only meant for non-Sis. Also, make sure that the nuts/bolts are torqued to spec. There might be something loose somewhere.
I don't think that the reinforcement plates not being installed is the cause of the clunking noise. The plates are meant to strengthen the mounting point on the lower control arm because the force of the thicker sway bar against the LCA can actually break the mounting point. I remember seeing an article (I think it was on the Progress site) showing how the bolt tears itself right out of the bracket because it's not strong enough.I never did install the plates for the endlinks, which explains the "clunk" noise. I was in such a hurry at my friend's shop trying to get two projects at once. I'll install them this wed. and see if that solves my "clunk" issue.
Ouch!!Here's a couple of pics I found on another forum that shows the problem if you don't use the reinforcement plates.
View attachment 51483 View attachment 51484
