Pauly's "You're my boy Blue!"
No I thought you were talking about the taillights?
No, we were talking about the headlights. The taillights already have resistors, yes.
I ordered the resistors for the switchback signal lights and the DRL lights for the headlights.
Finally had some time to work on these. Almost finished.
@Blimpcity
Installed :)
They have the static issue on the radio when pushing brake just as you had. It's not as noticeable as I thought it would be. I don't listen to the radio much at all, but will be checking all possible options on how to remedy this however. Really happy with the look.
Very nice. A small change with a big impact. It's subtle but effective.
edit: Are you guys getting frost and snow yet?
Thanks Nix.
No, not yet, but it snowed 4 hours north of Quebec City last night. Usually starts sporadically in November.
Camera takes terrible night pictures, buy here they are in case someone is interested.
I still need to change the halogen reverse bulbs for LED ones. Also, need to put a little hot glue to seal up a small gap in the trunk opening. This gap is unseen when the trunk is closed, buy water runs down the channel and may be able to go into this gap so will seal it up to be safe. I'll post pictures of the gap later when I do it.
Then there is the slight radio static noise This only happens when the brakes are applied. I need to research this to see what can be done about it. Off the top of my head, I'm thinking to replace the supplied resistors. At this time I don't know what else I could do to try to get rid of it. :think:
REVERSE LIGHTS....
LEFT SIGNAL LIGHT.....
Pretty sharp! Getting closer to buying a set for my coupe and tinting them. I may need some pointers...
Thanks. I'm certainly no expert. It was my first time. I did a lot of research before. I'll help you out if I can though.
Looks really good, I really need to wax mine too before the snow and the salt.
Pauly how much did you pay for your rims?
Ive got a guy on kijiji offering the same ones, in good condition, with all season tires for 600$. Good deal? I'm in Ottawa
I was gonna try and offer 500
