I had the same problem with both. My connectors were not getting far enough down into the pin slot, so there was no contact being made. I was really scared to push the pin in too far because it was a tight fit and I knew it would be very difficult to get out. But once I got the pins down far enough they had contact and everything lit up. Hang in there. I know how it is to have to take apart the dash and put it back together without success. You will get it.I have civic 2012 purchased in April 2012. I have been watching this thread for long. Got inspired and finally decided to add temperature sensor and rear view camera. This was my first trial and I was not able to execute either of the project successfully. The problem was with the 32 pin connector. I purchased JAE pins as mentioned in the thread, but it does not seem to get connected. Can you please help me with how to crimp and connect with the 32 pin imid and tach connector. I am very much disappointed, any help will be appreciated.
No... not just sitting in the trunk -.-
Neither are easy mods so don't be discouraged. It takes time and patience, the feeling once you completed it is priceless. You can do what Paul mentioned and work your way back checking each connection. I'm still in rehabilitation since my nervous cord injury but I'm still about to check the forums on my phone.
I had the same problem with both. My connectors were not getting far enough down into the pin slot, so there was no contact being made. I was really scared to push the pin in too far because it was a tight fit and I knew it would be very difficult to get out. But once I got the pins down far enough they had contact and everything lit up. Hang in there. I know how it is to have to take apart the dash and put it back together without success. You will get it.![]()
